Import .dwg to Revit as a base point
    Hello all,
    Could you please tell me which is the procedure of importing a dwg. file into revit, having it as a base point in order to start to do the project in Revit? [ How I will have the correct coordinates? / In which discipline I should import the .dwg ? ] and any other important configuration that I need to do.
    Thank you in advance!
    Maria
