Hatch 22
    Hatch 22
    We have recently started using Hatch 22 for Revit 2017. Is there a way to make the newly created hatch to resize at different scales? They were created at 1:1 scale and that's where they stay no matter what scale is chosen.
    That's a Revit thing.
    Until 2018.2. though.
    Starting in 2018, you can scale the patterns directly inside Revit.
    (way past) time to upgrade!
    Dave Plumb
    BWBR Architects; St Paul, MN
      Drafting patterns wont change with the view scale (think paper space). Model patterns will resize with the view scale (model space).
      If you want a new size of .pat file to import im anything earlier than 2018.2 you' ve got to make/ find a new one. I and others here are using pyrevit's make pattern tool to create hatch patterns, its so simple to use and (pre 2018.2) you can just select your detail lines, scale them and make a new one.
      Btw- pyrevit is free.
        As already mentioned by @Elton, pyRevit is a good option and is free!!:laugh:, regards
        E.A Poe
          Thanks for the replies. I did not know that we could now scale patterns inside Revit
            The HatchKit Add-In for Revit can copy, rescale or rotate any fill pattern within your project.
