Room Tags
    Room Tags
    Hi Guys.
    I have a small problem, when i want to place my room tag on the floor, it highlights the below room tag and sometimes on upper floor it claims there is a room tag already which is not true at all. Where can the problem be? any suggestions, Thank you for your time.
    Check the heights and ref. level offsets of your already placed rooms.
      Cut a Section through the room and turn on the Room Reference and Interior Fill sub-categories.
      You'll see where the room below ends.
      My guess would be you've got a floor that's either not Room Bounding, or is less than 4' above the lower level
      Dave Plumb
      BWBR Architects; St Paul, MN
