Net Area Calculations
    Other than an area plan and manually placed area lines, is there a quick way to get a net area calculation? For reference, this would go from wall face to wall face, excluding things like casework and equipment (barber chairs, therapy equipment, etc.)
    chad
    Using Revit lt '18, I have gotten some use from the "export-room/area report
      Once upon a time there was an add in called Room Book for Revit. Not sure if it still exists, but I think it could do this type of thing.
      Andrew Harp
      BIM Manager GHD
        Rooms in lieu of Areas will give you paint to paint or net areas
