I have some questions to interface RAC 2011
    Hello. The interface of the bag so the toolbar is not visible blur. I do not know how it would solve all your help
    Did you check your videocard on compatability?
      You can use the image for illustration for me?
        Find out what video card you have. Check the Autodesk website whether this is supported.
        You can also try to uncheck Hardware Acceleration (see attached images)
          Graphics Hardware List
          http://www.autodesk.com/us/revit/revit_graphics_hardware_-_graphics_hardware_list_final.html
          edit- as maxwell smart said 'missed it by that much!' but you won't get lost now!
          elton williams
          Forum Addict
            Also disable the Aero Theme on your desktop...
              I did as you said, that it was probably my leaving card is incompatible NVIDA GT 525M. Only officers used as such. Thank you for your interest in my article. I come from Vietnam. I can get acquainted with you?
                Disable Aero and move your quick access toolbar bar to below the ribbon...might not have to move the toolbar, but sometimes it helps...
                  We had a similar problem with our Lenovo T-series laptops.
                  They have NVIDIA Optimus graphics. My hardware guy tells me that's a "switchable" graphics chip.
                  When we had a second screen attached, it worked fine on the second screen. Dan says that's because it's not longer using the built-in graphics.
                  Moving the QAT below the Ribbon "fixed" it for us.
                  Dave Plumb
                  BWBR Architects; St Paul, MN
