Dependent View outline not visible
    What controls the display of the outline of the dependent views as seen in the parent view? I can see it fine in the out-of-the-box template, but not in my file.
    Yes I have Properties > Extents > Crop Region Visible checked On.
    I can place a Matchline and a View Reference that work correctly. I just can't see my child view outline from the parent view.
    Thanking you.
    Thanking you.
    If you are talking about view crops (??) they can still be view independant. Which is a good thing.
      Are they hidden in view?
      John Karben | IMEG Corp.
        Callouts need to be turned on to see the dependent view boxes.
        chad
          OK. Thank you all. I've got it showing in floor plan views, but they are not showing in an Elevation parent view.
