Slab Edge on Sloping Floor
    When I place a Slab Edge on the lower edge of a sloping Floor I get a gap between Slab and Edge as shown in the section image 01.
    If I edit my Profile to raise the inner edge by a nominal amount as shown in image 02,
    I can get the desired result back in my section, see image 03,
    Is this a reasonable way to solve the problem? Are there any issues with this method that I should be aware of?
    Thanks in advance,
    Anthony.
    you could just give the profile a vertical offset so the gap disappears.
    Mark Balsom
      Mark,
      I was hoping to maintain a nominally correct dimension on the outside of the setdown, but your suggestion is certainly an option. Thank you very much.
      Anthony.
        Originally posted by anthonyB View Post
        Mark,
        Anthony.
        If you have a Depth Param in your profile just ADD the vertical offset (25mm in your case) to you Depth Param and you end up back at your nominal depth. Its just a fudge.
        Mark Balsom
