Best way to model capping around 3 sides of a skillion roof
    Think im in brainfade. Im looking for the simplest way to model the capping around the 3 sides of an 8degree pitch skillion roof. Yes, seperate pieces work, but is there a way to do it as one sweep etc? The capping extends 200mm onto the corrugated roof, and 75mm down the fascia. Because of the pitch, when i tried it as a sweep with drawing profile along high front edge, the capping would angle in to the fascia down the sloping sides..i cant do it as a fascia in one piece for the same reason. Maybe each side seperately.
    Any other ideas?
    Have you got any images to show what you are trying to achieve?
      Thanks B, I solved it.
      Best way was to model 2 profiles for the capping, one at 82 degree down pitch for high end of skillion, and one at 0 degree (90 degree) for the rising sides, and apply these as fascias. Amazing how my brain is clearer in mornings. Clarity, love it.
