Hatch pattern on floor sloped to center drain
    Having an issue with the floor hatch pattern when the floor is sloped to a floor drain. Is there a way to get all the tile to align in the same direction?
    Thanks
    hover over one of the hatch lines and hit tab until it highlight, then rotate it 90 degrees. that will rotate the entire hatch for that section. Then use the align tool to align the hatch with the adjacent one. I did the left side of this pic...
    Dan
      Thanks,
      For some reason I all was use the align tool when locating patters and that wasn't working this time.
      Ok Second question:
      In elevation is there an easy way to align all instance of one hatch with a particular datum?
        You can align so long as they’re not at right angles to each other.
        No, you have to manually align all instances.
        Sent from my iPad using Tapatalk
        Greg McDowell Jr
        about.me/GMcDowellJr
