Problem using RAC2009 template on RAC2012 project
    Hi guys,
    I just switched from RAC2009 to RAC 2012. When I was using RAC2009 template on RAC2012 project, the rendering i produced with the camera is all black except the image. Does anyone know how to solve the problem?
    Thank you very much!!
    The version of RAC2009 is Chinese, RAC2012 (English) , OS using is Windows 7(CHN)
    The materials have changed since then....you have to reapply the correct maps to your materials....
      I dont believe that the materials have changed that much. Should still be upgradable from 09-12...
      Does a native 2012 project render fine? If not, it´s probably a faulty installation of the Material Libraries.
        Had the same issue when I went from 2009 to 2011...all my custom materials had to be reapplied...
          Yup, you need to reapply the materials... I had this problem too.
            problem solved. Thx guys~!!
