Door Family
    Door Family
    Hi Guys
    I am thinking how to make a custom made door family in revit.
    This one is what i have to load into a project. In the middle part there is shape like star. How can i make this type of a door?
    Thank you for your help in advance.
    Is it a folding door with a hinge along the center? Do you need it parametric in size? What do you need the end result to be, documentation-wise? Do you want it to be able to show open and closed in 3D?
      This is just a normal door with kind of triangular shape, and that star shaped part in the middle is beveled outside.
        or maybe i need a triangular shaped door for now, because i even dont know how to make a triangular shaped door.
          I guess that can be 2 nested panel family with the desired shape and size by extrusion, the triangular form can be done with a simple extrusion using reference planes or not if the panel doesn't need to be parametric, for the beveled form maybe void extrusions can achieve the goal, regards
          E.A Poe
            Hi Andres, Thank you for your help, But could you please explain this part a bit ditailed. This is first time i started working with family.
              ok give me a while and i'll try to model the door panel for explain you my idea
              E.A Poe
                may you post some additional information for the door I mean a plan and maybe a section?, that will help a lot to do this, regards
                E.A Poe
                  Long story short; I'd start with a Generic Model family then change it to a Door Family, then turn on the "Cut with Voids when Loaded". I'd create an extrusion then swap it to a Void to cut the walls when joined. I'd make the Angle flexible & all that entails with associations to the modeling.
                    Hi Andres . Thank alot for your input.
                    The Height of the door is 4m and below i have attached plan view. wooden profile around the door is 700mm.
