dosent open elevation
    I began to learn the new Revit but when ı opened the page ,doesent elevation . no elevation over the page can you help me this is regard
    welcome to the forum. Can you post some screenshots about what's going on?
      this page empty no elevation
        On the page
          mim-ozge,
          I would suggest a quick read of http://revitforum.org/showthread.php...sons-maybe-why Almost certainly, the reason why the view is blank is within one of the 33 reasons.
          Cheers,
          Ian Kidston
          http://allextensions.com.au
            Sorry, can't see the inline-attachment. Only the last one you posted. Which shows as an "attached thumbnail" here...
            I would follow Ian's suggestion and look in that thread...
              Did you start with a template? If not, it will be blank. If you chose one of the OOTB templates, then the elevations will be there.
              OR
              Just go to the elevation tool and put them in.
              Dan
