Revision issue ordering
    All,
    We have a strange one. When placing the revisions on a sheet the revisions are listing A, B, D, C instead of sequential even though they are correct in the Sheet Issues/Revision dialogue box.
    If I try to reorder them using Move up/Move Down I can force A, B, C, D but the date issued doesn't stay with the revision description.
    Any ideas.
    Is the sequence in the numbering options dialog correct?
      If this is a revision schedule inside a Title Block you should also check how that schedule is sorted.
        Yes the order is correct in the dialog box. And if I change the order (bump it up) the date moves in the dialog but NOT on the sheet.
          Can you post a screenshot of the revision dialog box ?
          Kamran Mirza
            Here are the three screen shots
            One is in the Manage Issues dialog.
            The second is how it appears on screen
            The third is if I sort by in the Family but then my Construction issue (1) ends up on top and out of date sequence.
            The forth is a picture of a monkey on a bike... Not on sheet.
              Have you tried changing the Per Project/Per Sheet option?
              When set to Per Sheet the revision # on the sheet will start with the first letter/number in the sequence.
              When set to Per Project the revision # will maintain the letter/number.
              John Karben | IMEG Corp.
                Currently it's set to Per Sheet. If I change it to Per Project it actually gets worse.
                  I think josephpeel might be on the right track.
                  * Go to your sheet view and Edit the title sheet family.
                  * Look to the Project Browser and select Schedules > Revision.
                  * Now from the Properties dialog, hit Sorting/Grouping.
                  * Check the options for Sort By:. You may need it to be Revision Sequence.
                    OK Seem to have found a solution thanks to many prompts in the right direction.
                    Edited the title block family.
                    Added Revision Sequence to the Scheduled Fields and sorted by:
                    1. Revision Sequence
                    2. Revision Number
                    3. Revision Date
                    Then under Appearance I made Revision Sequence a Hidden Field.
                    Thanks again to everyone who contributed.
