Stairs Problems
    Stairs Problems
    Hi Guys, I have stairs going from level 0 to level 3, and on level three only half of the stair should be visible but when i draw the stair and look into plan view the part of the stair that should not be present on level three is there. On 3d view everything is ok. What is the problem? I tried bt could not find a solution. Thanks for your answers.
    Looks like that is the intended way stairs work. They do need a big overhaul if you ask me.
    Seems there are just tricks and workarounds.
    https://www.revitforum.org/architect...iew-depth.html
    https://forums.autodesk.com/t5/revit...e/td-p/3405241
      guys any inputs please?
        Check your view range. Set the top and cut line to the same height and see if that gives you the look you want.
