Change Common Edges Per Element
    Greetings!
    I'm drawing a floor plan for a house and I need to have the walls displayed a certain way. I'm trying to hide the common edge lines in a particular wall, and still have the ability to have them on in another wall. I know how to hide common edges for all walls, but I am having trouble to do this per specfic wall. Can this be done in the view specific element graphics?
    I am using Revit Archetecture 2017.
    Can you just set the View Properties to Coarse mode?
    If that doesn't work for the entire View, you should be able to the just the Walls to Coarse in your View Tempalte
    Dave Plumb
    BWBR Architects; St Paul, MN
