Deleting Text Style
    Deleting Text Style
    Hello,
    Is there any way to find out a particular text style in Revit Project which is used somewhere in project which we don't know. I tried searching everywhere in project but couldn't find it. In AutoCAD we have "Quick Select" Option to find a particular things. Also suggest if there is way to delete those irrelevant text style which is used somewhere in project.
    Thank You
    Create a text of the same type, then "select all elements in entire project", then unselect the one that you've just created and then you can delete the ones that remain selected.
    There's also a good add-in called 'Project Sweeper'.
      There are also some addins that will let you swap types. I know CTC's BIM Manager Suite has one - it rocks.
      chad
        Great tip!
          There is a Dynamo Script that does this, even get some of the unknown dim style ones out that can't be seen thru settings
          Dwane
            That's great trick.
            Thanks @Jamie
              Nice trick but I was just wondering if there is any way without using addins. Though addins are helpful in complex situations.
              Thanks for the reply @ cellophane
