Filled region in 3d view
    Is there any way that one can add a filled region to a 3d view?
    In the sample attached I need to add the area (retail, arcade, etc) to the section. I really would want to do this without having to first turn the view into a jpeg, then photoshop over it.
    Sorry but the answer is no. At least not natively. The section box cut face of 3D geometry is pretty much useless in Revit in terms of being a thing you can calculate anything from. You could use VG to alter the cut pattern but that would apply to all cut faces of the same type. You could hack it though with overlayed views. Or photoshop.
      not with native revit except if you insert a pdf or dwg "in all views" it will show in your 3D view also that might be an option, also take a look at revizto it allows you to associate other views and they will call up in your 3D it might give you what you need.
      https://www.youtube.com/watch?v=HdhxY6yo63o
      https://revizto.com/en/
      Whats the objective of these linked filled régions? If I can see what you are trying to produce exactly I might have a workaround for you.
        Originally posted by Karalon10 View Post
        ...except if you insert a pdf...
        Can you please tell me how I can insert a PDF in Revit
          You can superimpose a view that does allow filled region and draw it there
          "-Bueno, pues ahora que los dos nos hemos visto el uno al otro -repuso el
          unicornio-si tu crees en mi, yo creeré en tí, ¿trato hecho?"
          Lewis Carroll
            You could model a wafer-thin element of some kind, on a non-primary design option...
              pass it through autocad (ie link the pdf into autocad) then link your cad drawing into revit.
              Theres also this option in revit
                What a kludge.
                  well im not sure why you would need filled regions in a 3D view, handle it with hatch patterns and filters would be a better option
                  If you are trying to show the room spaces in color in 3D views there are better workarounds just dépends what he is trying to achieve, but yes passing a pdf into autocad is a pain, but I've done the same with excel spreadsheets, this way it keeps a "live" update as the dwg updates the excel spreadsheet like an XREF and then revit does similar with the link. It works, but its double handling
                    If unused elsewhere: create a simple mass and have it shown?
                    Alex Page
                    RevitWorks Ltd
