Revision Tag size and shape
    Is there a way to modify the size and shape of the Revision Tag triangle. I can see that the Revision Tag only contains the text element, which I can make larger or smaller, but I cannot see how to adjust the triangle. Is this possible, please?
    You´ll need to find the revision tag in the project browser, open it, and edit it to fit your needs. (And then reload to project)
      So you've opened the family Revision.tag and only see the label? Check V/G for the lines, perhaps they've been turned off. Should be a triangle visible... could be any shape or size you want!
        Munkholm and Steve: I had edited the family but fell for the trap of not thinking about VG. Thank you very much.
