Hidden Dialog Boxes after printing to PDF problem is back!
    This was a big problem in 2016 - after printing to PDF, all my Revit dialog boxes would appear hidden behind the main window, such that I would have to click elsewhere in the Revit window to make the dialog box show up, while Revit made that complaining "ding" sound every time. Also clicking the R button would apparently make the menu open hidden, so then when I clicked away it would show for a split second right as it was closing, meaning I couldn't pick anything in the menu. It would do this until Revit was shut down and restarted.
    Last week I installed the Revit 2017.2.2 update, and now apparently it's doing it again. I haven't seen that issue at all until now. Anyone else having this problem?
    I never experienced that in R2016 and am using R2017.2.2 daily and haven't seen this at all. Sorry, but I'm glad that I can't join you ;-P
      This is still happening in 2018.3.1. Print to PDF, and then all dialog boxes are hidden until I click somewhere in the Revit window. Plus the File menu hidden unless I wait 30-60 seconds for it to appear.
