Autodesk STL Exporter 2018
    Can anyone with Visual Studio and some programming skills build this add-in?
    https://github.com/Autodesk/revit-stl-extension
    It would be nice if Autodesk would just build and release it for 2018.... It has only been out for 5 months now.
    Jeffrey A. Pinheiro, AIA, LEED AP
    TheRevitKid.com / BIM After Dark
    studio.bad architects
    Jeffery;
    I was able to pull and .msi file out of my 2018 Deployment.
    There's an option in the Deployment build to install the STL Exporter.
    That options doesn't work, but it did add the file to the Image
    I found STLExporterForRevit2018.msi under
    \\MyDeploymentPath\Img\Updates\A0A20D93-E364-4F9A-A148-5916EF9D2231
    Not exactly "available for download", but it can be found
    Dave Plumb
    BWBR Architects; St Paul, MN
      I think it's available for download for Autodesk Subscription members.
        Thanks guys... I actually just had my buddy build the DLL for me... Didn't think to look in the image! Also, I don't see it in the Subscription area?
          Shows up for me under Updates and Addons
