Creating a custom curtain wall system in revit
    Hello all. I would like to create a curtain wall system on my building but I am facing a few difficulties.
    [COLOR=#666666][FONT=Tahoma]trying to achieve. The attached image of revit is the current model i am working on. As you can see, i did in-place mass to create the external plane of the facade. I divided the surface of my massing. The panels that i am trying to achieve are 2400x600mm rectangular panels. However, when i input such dimensions in my divided surface, the grids will follow the shape of my mass. is there a way to keep the divided grids consistently 2400x600mm and parallel to the ground? Instead of it slanting and following the plane.
