upgrading to Revit 2018
    This is the first time we are upgrading to a new version of Revit. When upgrading a Revit file that contains several Revit linked files, will those links be automatically upgraded or do we have to upgrade each link separately before upgrading the central model?
    They will be upgraded when you open the model which contains all the links but .You need to upgrade them individually when you open them
    Sent from my ONEPLUS A3003 using Tapatalk
      It will temporarily upgrade the linked files during the central model upgrade so you'll need to upgrade them individually.
        They will be upgraded temporarily while the file they are linked to is opened/upgraded. You have to upgrade each file on their own. Upgrade the linked files first if they aren't linked into each other. If they are inter-linked then you'll endure waiting for them to upgrade temporarily regardless...unless you assign each link to its own workset and Close those worksets prior to opening and upgrading the files.
          When you save the link it does not reflect to the linked files.
            Both, which is annoying.
            What i mean is:
            When you tell it to upgrade a central, if it FINDS the links, it will take the TIME to upgrade the links (which can make the upgrade take about 4x longer than normal), but it only upgrades it in to MEMORY... It doesn't save them.
            This basically means that you also need to upgrade them individually, or youll be stuck waiting for them to upgrade EVERY time you open the real model.
            To combat this, my upgrade process goes like this:
            1. Rename all the files (change last three characters from R17 to R18). This makes the models not find the links, so it doesnt upgrade them in to memory.
            2. Upgrade them all one at a time using DFC and Save As.
            3. Go to Manage Links and use Reload From, to pick the new versions of the files.
              DFC
                Ok disconnected from Central [emoji3]
                  we have a high rise office building with each tenant space linked in to the base file. So each tenant space (approx. 25) needs to be upgraded individually then reloaded into the base file?
                    Yes. Revit doesn't save back to linked files, it just loads the current state of the link. Follow Aaron's steps in post #6, starting with the tenant space links and then the base file. Trust me, doing this in a particular order will save you frustration.
