Topo hatch not showing in just one elevation
  • biff
    Originally posted by chris.macko View Post
    Check the view depth too. Sometimes if the section depth is set very close to 0, the topo hatch won't display.
    Any depth less than 28mm at last investigation, or it may well be the imperial inch at 25.4 mm. Always wondered why.
  • chris.macko
  • sdbrownaia
    Looks like the topography is turned off in the second image. check VV/VG and make sure its turned on or not on a workset that is off, or is the site on a linked model that maybe off in that view.
  • jgardner
    started a topic Topo hatch not showing in just one elevation
    For some reason, the view properties of the topography are showing incorrectly in just one of my elevations. Phasing all seems to be correct, and the view template is unchanged. Ideas? (photos attached: first is how I want it shown, second is how it is appearing in one elevation)
