Underlay change color
    How can I change a color in an underlayed Revit linked drawing?
    I have put a linked Revit drawing into my project and I want to change an underplayed colors of walls, which could have a different color than my walls etc.
    Cheers
    View filters
      I am using 2017 LT and there is no filter in the Ribbon.
      Any ideas ?
        Visibility/Graphics -> Linked Files -> Change the file to Custom Settings, go to the Model Tab in there and change the color of the cut lines and cut patterns as desired. Be aware that this will apply to all walls from the linked file. For any more control you will need Filters and those are missing in Revit LT.
          I have done this already and my walls and an underlayed walls have changed colors.
          I am wondering,how can I maintain my walls in different color and change an underlayed layers/file etc.
          Yes,I am using LT version.
          Thanks for you help
            You could try the coarse pattern setting for walls. Would need to set this info in the linked model
              Thanks for you help
              Are you sure you went to the Linked Files section and not the regular model categories?
Name:	linked model.jpg
                Thanks for your advice. I did not go via Custom, but I will try and see if LT allows me to go throught.
                Thanks again
                  I use LT version 2017,so I do not have an option in Revit Link more than halftone and underlay
                    mmmm, did not know that. Well than I have no idea what to do other then to buy the full version of Revit :hide:.
