Adding Parameter -Cylinder
    I am trying to add a parameter-diameter to a cylinder and it does not work.
    In Type Properties I have got a parameter Diameter and when I type a value, it does not change a typed diameter.
    What Am I doing wrong?
    I am adding a dimension for diameter and a Label for a Parameter Properties, when I save it - it does not work?
    I'd say, make an extrusion and label the outline with the radius.
    If you really need the diameter parameter, just make that and add a formula to the radius parameter =diameter/2
