Level of Details -Window
    Hello all,
    Could you please tell me how can I change the level of detail in a window?
    I would like to see more details each time that I move from Coarse to Medium to Fine.
    Thank you in advance!
    Maria
    In a window family?
    This depends how your family has been set up.
    But when you click on an element in your family (lets say the window frame) you can then click on "visibility" in the properties of that object and set the detail level at which it is (or isnt) visible.
    So what you could do for example is have the void visible in all 3 states (low, med, high visibility)
    The border/frame visible in medium and high
    and the glass only visible in high.
    This allows you control over your views but these sort of controls are built into each family.
      Thank you a lot!
