cant find libraries
    cant find libraries
    iv installed revit 2012 but i cant find any of the components, iv tried looking in programme data where it used to be in 2011 but not anymore, does anyone know where i can get them or find them?
    also a quick question, is revit a 64 bit programme by default?
    In a 64 bit installation, the default OOTB library locations is C:\Program Data\Autodesk\RAC 2010\Libraries.......
    Revit is not 64 bit by default. If you have the standalone version of RAC, you can download both a x86 (32bit) and x64 (64bit) version. Obviously both will only install on the appropriate OS. My memory is that the suite came as a single USB which I had predesignated as 64bit when ordering.
    Ian Kidston
    http://allextensions.com.au
      thanks for the reply
      iv tried that location but i still cant find it, iv tried re installing it but i still cant find them, is it possible to download them do you know. im using the student version from the autodesk website, would that have anything to do with it?
      also on the 32-64 but question, i downloaded it from the site but it was a single file for both versions, do i just assume it installed as 64 bit if my laptop is able to run it as 64 bit
        You can download the libraries from http://revit.autodesk.com/library/html/index.html All of the ootb families, and a lot of other stuff, is also available from http://seek.autodesk.com/
        If you click the drop down button next to the blue question mark on the right hand side of the top bar, select "about" this will show you the build number with (x64) if installed as 64bit
        Ian Kidston
          From the Autodesk website:
          Release 2012 – First Customer Ship – April 2011: Starting with the release of Autodesk Revit Architecture 2012, Revit content can be added during the installation process (or after installation using the "Add or Remove Features" utility). For more information, refer to WikiHelp.
            iv tried those links but they only give the 2011 content.
            i eventually found the folder where the libraries were but there was very few components in it, the window fodler only had 6 windows in it whereas 2011 had 20+
            im really confused as to why i cant have a decent size library like in 2011
              Must have missed this.... :beer:
