Resolving Materials
    Resolving Materials
    I use two different machines with two different USB drive IDs. Other than changin the mapping of the drive letter, is there an easier way to resync paths? From my Viz days I recall being able to set paths
    Under the Big R>options>Render> you can set the path to your library. as long as the material maps are there revit will find it. so if you don't have a network location you need to copy the image maps to the location you have set this path too.
