Extra @#%$ in the .INI file
    Can I delete all the extra Content sections from my Revit.INI file?
    I'm installing just the English content, but my default Revit.INI file has a dozen sections like this"
    [DirectoriesJPN]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2018\Family Templates\Japanese\
    DataLibraryLocations=Library=C:\ProgramData\Autode sk\RVT 2018\Libraries\Generic\
    DefaultTemplate=建設テンプレート=C:\ProgramData\Autodesk\R VT 2018\Templates\Generic\Default_M_JPN.rte, 建築テンプレート=C:\ProgramData\Autodesk\RVT 2018\Templates\Generic\Default_M_JPN.rte, 構造テンプレート=C:\ProgramData\Autodesk\RVT 2018\Templates\Generic\Default_M_JPN.rte, 機械テンプレート=C:\ProgramData\Autodesk\RVT 2018\Templates\Generic\Default_M_JPN.rte
    [DirectoriesKOR]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2018\Family Templates\Korean\
    DefaultTemplate=시공 템플릿=C:\ProgramData\Autodesk\RVT 2018\Templates\Generic\Default_M_KOR.rte, 건축 템플릿=C:\ProgramData\Autodesk\RVT 2018\Templates\Generic\Default_M_KOR.rte, 구조 템플릿=C:\ProgramData\Autodesk\RVT 2018\Templates\Generic\Default_M_KOR.rte, 기계 템플릿=C:\ProgramData\Autodesk\RVT 2018\Templates\Generic\Default_M_KOR.rte
    I assume I can just delete those sections. That's not going to hurt anything is it? I'll never use them.
    I will, of course, keep the
    [DirectoriesENG]
    section
    Dave Plumb
    BWBR Architects; St Paul, MN
    [DirectoriesJPN]
    [DirectoriesKOR]
    [DirectoriesENG]
    section
    DirectoriesENU is the one you want to keep, not ENG... Unless you are in England.
    Wont hurt anything. I dont have any of that crap in mine. But im sure itll fail if i try to switch languages.
      ach du lieber!
      I knew that. Thanks for catching it.
      There's a [DirectoriesENU] section up near the top of the .INI, and all the rest of the junk is farther down after the Help file.
      Why do they do that? I already told the Deployment I only want American English!
      Dave Plumb
