Hi basic question but cant find a answer anywhere..
Simple hip & valley roof - house is at one level - garage is higher.
I create the roof at standard level then select the eave on the garage "plate offset from base" and adjust this say 3 course higher.
This gives me correct garage height but the shared valleys are now sqeauwiff (not sure if thats a word..) ie. valley line is not at the intersection.
How can I fix ? Align eave will fix valley but then height is wrong?
Thanks Grant
Thanks Grant
