AUGI s article re collaboration - Civile3d - Revit
    Browsing through the new AUGI. https://www.augi.com/uploads/augiwor...AW201708LR.pdf
    On page 13 the talk about collaboration/coordination btw Civil3D and Revit.
    They are only talking about surfaces etc – BUT there are still no (easy) way to coordinate civil pipe work with Revit?
    Are the only options still:
    - Remodel in Revit
    - Dwg import into revit
    - IFC import to revit
    JH
    Autodesk must have had good reasons to bring in a fourth option. Underlay as .nwc.
    Each options has it's pros and cons. From a Revit point of view, but also from a AutoCAD (or fill in : other software used by the counterpart) It is up to the user to pick the best suitable options. Did you try .nwc as underlay? Did it provide a good alternative for the others?
