sort schedule by (French) date
    hello
    i have a schedule of the sheets i edited with the number, name.... and date
    In France, we use to write date like this : day/month/year (xx/yy/zzzz)
    but the problem is that when i sort my dates it works only with the day
    it'd works with UK/US date (zzzz/yy/xx) but how can i do for French date
    an example below:
    Phil
    Freelance WWTP/HVAC Designer
    Revit 2019
    There isn't a date parameter, so sorting is always alphabetical. yyyy/mm/dd works for alphabetical sorting, but the other way dates are often written (in the US) is mm/dd/yy and those would have the same issue (when there is more than one year). You could have three parameters (month, day & year) and sort by those, with a combined parameter to display the date in a single field, but that may be more work then is desirable.
    Julie Kidder
    Architect + BIM Director
      thanks
      one of my colleague told me that there would be a way to sort the sheet by date using the sequence of the revisions but we didn't succeeded ti find the paramater of sequence...
      Phil
      Revit 2019
        You can sort by current revision.
        Julie Kidder
