Import CAD Problems- Geometry in dwg file has extents
    Hi there,
    When I import a CAD drawing into a Revit project I have got the message "Geometry in the file extents greater than 1E9. Data exceeding that range will be truncated", or another message is saying about:
    "Geometry in dwg file has extents greater that 20 miles"etc.
    When I zoom to fit I can find an inserted drawing, but then I am loosing another drawn object etc.
    How can I find in my model/on the screen already drawn objects,while I have got an inserted drawing in my project?
    Please advise,
    Regards
    Pete
    Are you using Worksets on this project?
    If you are, a handy way to find things is to open a fresh Local Copy, open a 3D View and Zoom Fit.
    Then zoom out a little bit farther and select everything by using a big Crossing Window from the lower right corner to the upper left.
    Since you're using Worksets, you'll get the "Element not owned" icon pointing to everything. From there you can select again and Isolate.
    But the true answer is to open the DWG, find out WHAT is miles from the Origin, and fix (delete) it.
    Dave Plumb
    BWBR Architects; St Paul, MN
      If the whole dwg is positioned far from origin and nothing should be deleted then one should move all the content closer to 0,0,0.
      Revit add-ins: Purger (delete UNUSED and selected line patterns & line styles, find & delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager (with bunch of other features) at Revit Exchange Apps, View Filter Manager ML
        Just to pile onto this. In could also be in 3D and it could be stuck in a block that is way off in space.
          A new trick I learned: use COPYCLIP on the part of the CAD file you need (assuming you have and can open it in AutoCAD). That will create a new file with only the geometry you need, AND it will maintain the coordinate system, which is important if you have to export and send things back to your civil/site engineer.
          I used to always move stuff in the CAD file to 0,0,0, but found it's better to use COPYCLIP so that the coordinate system is maintained, so that when I Acquire Coordinates my Revit model will have the same coordinate system. You can have the Site Survey Point more than 20 miles away from your Revit model, it just doesn't like model geometry that far away.
            So many way to tackle AutoCAD problems in Revit. One options that needs to be mentioned is the new abilities of the 2018 releases to work with GIS orientated dwg's is the georeference feature. Only downside might be compatibility as a hurdle. But I appreciate Autodesk effort to get these programme speaking to each other..
            https://envisioncad.com/tips/revit-t...in-revit-2018/
              I'm certain that 2017.2.1 can do the same thing. Also, 2018 still has the same 20 mile limitation for model geometry in Revit or linked CAD files.
                I think it requires the 2018 dwg as fileformat, not sure about dwg 2013 verticals.. I still have to check that.
                  Here is one explanation in dutch..
                  Voor civiele kaaskoppen only (..that is : a little joke..)
                  Civil Infra Benelux: Werksessie Best practices Coördinaten (1/1)
