I have noticed that with Revit 2017.2, whenever I link a .dwg detail to a project, the lineweights do not automatically change to reflect the same representation that they have in the .dwg itself. I have to go into the Object Styles and manually change it for every detail that I import. Anyone else have the same problem? Am I over looking something? This has never been a problem in the past.
LineWeights from .dwg files transferring
Have you lost your Import Lineweights file?
There's a little-known and well-hidden option that sets your DWG Colors-Revit Lineweights mapping.
It's on that little tiny arrow at the bottom right of the Insert tab's Import panel:
I think by default, it's somewhere under C:\Program Files, but the dialog box will show you the path.
This is a simple text file that has a row for each Color specifying the Revit Lineweight.
First row is what lineweight is assigned to Color 1, second row is Color 2; etc, etc up to 256.Dave Plumb
BWBR Architects; St Paul, MN
Originally posted by DaveP View PostThere's a little-known and well-hidden option that sets your DWG Colors-Revit Lineweights mapping.
"Just don't explode DWG files" is good advice, that is immediately ignored because...reasons...
Setting that aside, now that we've exploded...-
Channel: Blog Feeds
March 16, 2021, 01:16 AM -
Hi people! I'm trying to import a dwg file in Revit. I made this dwg in 3Dstudio max, it is a sofa, so a complex geometry. When I import this file, some...July 3, 2018, 08:23 AM
I have imported .dwg file (geo site plan), and it's unworkable. The lag is awesome. There is nothing on my .rvt other then the .dwg witch is under 1Mb....June 27, 2014, 06:55 AM
Edited:
How to export plan with sections to 1 dwg file? in my case i showed plan + section on sheet, and after import it gave me 4 dwg files.. ...April 22, 2011, 10:06 AM -
I have a .dwg linked to my project that is used as a on some sheets, and I occasionally need to alter the .dwg file and reload it in Revit....October 26, 2020, 07:25 PM
Monumetric Footer In-screen
