Revit Extension Error message
This topic is closed.
    I recently unistalled some revit extensions and I get the following message
    I checked the 'do not show me this message again' box but it still shows every time I launch revit.
    Where am i supposed to make the changes necessary to remove this message?
    Thanks in advance!
    Juan Carlos Moreno
    Sisley Cosmetics
    Hi Juan, what Revit do you have?
    Did you get updates? What extension do you have installed? Do they work all fine?
    We need some more
    see you
    Julien
    P. DAC
      I innstalled the extensions that came with the subscription advantage pack (I think that's the name) but i uninstalled the extensions. I have also an extension called REVVED I think it changes the text to all CAPS and also Merges Text. That extension works fine but the message always shows up and I think its because I uninstalled the other extensions
      Juan Carlos Moreno
      Sisley Cosmetics
        You should check your Addin-directory. What OS are you running?
        I think the problem is that the dll- or addin-files are still there whilst the program itself is deleted. I think if you go to the Addin-directory and manually delete those files this should end the messages.
            I'm using Windows 7 Home Premium, I tried finding the add ins folder and found an empty one with a 2011 folder in it (also empty)
            it was in C:\Users\Juan Carlos Moreno\AppData\Roaming\Autodesk\Revit\Addins\2011
            Juan Carlos Moreno
            Sisley Cosmetics
              Have you looked in the Revit.ini file ? I know that Revit 2011 has improved the add-in registration facility using add-in manifest files, but from my understanding, developers can still choose to use the revit.ini
              If there´s no sign in the .ini file, maybe the below blog post by Ryan Duell can help ?
              Originally posted by Ryan Duell - Revit Clinic
              Disable Add-Ins for Revit 2011 Products
              There may be an occasion where you want to test Revit 2011 with add-ins disabled.
              By default in Revit 2011 products the Add-Ins components have been moved from the Revit.ini file to a separate location. While you can still utilize the Revit.ini for this release, the default location is now listed below.
              If you want to test Revit with all add-ins disabled [or selectively disable add-ins] follow the steps below:
              1. Close Revit 2011
              2. Locate the following folder:
              Windows Vista \ Windows 7 - C:\ProgramData\Autodesk\Revit\Addins\2011
              Windows XP - C:\Documents and Settings\All Users\Application Data\Autodesk\REVIT\Addins\2011
              3. Temporarily move the add-in files from the folder above to another location.
              4. Launch Revit 2011; add-ins will be disabled.
              When testing is complete you can move the add-in files back into the original folder.
                Thanks Munkholm! This was exactly what I needed. I was looking in the wrong folder for the extension file. I deleted the file from :
                and everything is back to normal. No more annoying Message
                Juan Carlos Moreno
                Sisley Cosmetics
