I've been stealing time away from the insanity of two jobs going full guns to do a bit of housekeeping (in anticipation of the next wave once these are drop-kicked out the door) and aside from consolidating all of our system family and component family content files into one, (itself child-linked in under our template proper)
I've been having a bit of a pan-content go at making sure that said content is ready to receive a beasting by Dynamo (come the time).
In particular, I'm talking shared parameters.
But I've a Klingon on my otherwise pristine file - with one SP listing on the LHS 'pick fields' of the schedule builder, but no placed instances have it (at least if I filter said multi-category* schedule by Parameter Exists) - how is that even possible?
*no this particular SP was never applied to system families - and I've checked them just in case
So then my suspicion lay with sub-nested families in the placed instances in project. Shared (children) would show in schedule (no other filters in place) - so it can't be them. So then the culprit MUST be an unshared .rfa that some how got the SP....
How the hell does one even start going about digging for that in a file of over 4000 families? :crazy:
BTW:
I've dipped a toe into Dynamo hoping it would have a means to dig into unplaced content - but a quick go using the "Parameter Exists" node from Clockwork points out that Dynamo, like Revit's schedules, appears 'only' interested in what's in the model space, not model. :banghead:
BTW:
