Copy/Monitor & Instance Parameters
I'm trying to copy/monitor some lighting fixtures from an MEP model and they copy well enough but there are a number of parameters that are instance based instead of type based and when copied none of the parameters copy over. Is this one of those "working as intended" things or is there actually a way to do this that doesn't suck?Tags: None
Got another issue hopefully you guys can help me out with.
Our electrical engineer is copy/monitoring over all of our mechanical equipment...-
Channel: MEP - General
September 23, 2014, 01:28 PM -
I'm looking for advices in using the copy monitor feature. I haven't use it yet, unless for testing.
What is the best...-
Channel: Structure - General Questions
December 8, 2010, 09:52 PM -
This a large project at ~186,000 sq. ft. and up until now our MEP engineer was modeling all the lighting fixtures. We now need to take over this scope...March 19, 2020, 11:17 PM
I have a 8 story bearing wall job. This is the first job I have heavily used copy/monitor for basically everything. The Architect has moved some shaft...
October 30, 2014, 06:47 PM -
I can copy monitor walls doors and stuff like that but how come I can't link in my Mechanical Consultant's model and copy monitor his pipes?
May 15, 2015, 01:10 PM -
Monumetric Footer In-screen
