project base point & survey Point
    hi,
    Kindly explain the difference between
    1. project base point (Clipped)
    2. project base point (Unclipped)
    3. Survey point (Clipped)
    4. Survey point (Unclipped)
    Mainly I am confusing about the difference between clipped and unclipped state.
    Thanks for guiding me.
    Dhilip Seshan
    +91 8124181665
    www.dhilipseshan.n.nu
    Hi Dhilip, that was already discussed in this thread:
    https://www.revitforum.org/architect...vey-point.html
    Regards
    E.A Poe
      hi https://www.revitforum.org/members/andres-franco.html
      it is not clear much confusing.
      Dhilip Seshan
      +91 8124181665
        Try Steve's explaination here
        Mark Balsom
          You can try these 2 topics in the help
          Move Project Base Point
          Help
          Move Survey Point
          Help
          Jeff Hanson
          Sr. Subject Matter Expert
            Don't ever "move" either the PBP or the Survey Point. It you always use acquire, publish, or specify coordinates at a point, you don't have to worry about clipped or unclipped.
            Aaron Maller
            Director
            Parallax Team, Inc.
              Clipped = changes actual position settings (generally not a good choice)
              Un-Clipped = Changes the symbol position only, does not actually change anything.
              As Aaron wrote, use the specific intended tools for managing coordinates and position and you can (should) ignore and avoid altering the symbols directly. If I decide I want to use the symbols (as useful markers) I only move them un-clipped.
