How to change type of linestyle of each function?
    i want to choost other style of line for above lines and underneath lines.
    Hi, Can you be more specific please? or if you have images it will be better, regards :coffee:
    E.A Poe
      solid and hidden types? If you want to create custom line types for above and underneath line types go to Manage/Additional Settings, Line Styles and create new styles with whatever line weight, color, and line pattern that you like.
        Ok i found that <beyond> are the lines lower from Primary range bottom line.
        Now i want to define the lines that are above the Primay range cut plane line. right now they are not shown. how can i difined them to show, and appear dashed?
        Thank you!
