Dimension on archwalls
    Hello,
    We have a House with "organic" form. There are walls with a archshape - a contur! each wall has an radius. Is there any way to catch edges of walls or axes,...
    How can I put Dimension on it? Is there a workflow?
    KR
    Andreas
    Arc length will do. Select the arc (exterior wall face, center of wall or interior wall face) then select the grid lines that intersect the arc. That will give the dimension between grid lines.
