Classification Manager - Revit 2017
    Hello all,
    I want to use the add-in Classification Manager. I had used it again in the past and all worked fine.
    Now, when I go SetUp and choose the database that I want, the only table that is displayed is the Omniclass Table 11 (for the US) and the Uniclass Table En (for the UK)
    Do you have any idea why does it happen?
    Thank you in advance!
    Maria
    Solved....
      could you post how you resolved the issue in case someone else has the same question?
      chad
        Actually..firstly I just chose the element and after I selected the 'Assign Classification'....
