Colour Shemes and Phasing
    Hey there,
    I have been presented with a situation that I am sure I had worked out before, but cant find my solution / workflow.
    We use a solid, light grey surface pattern for all of our existing elements to easily distinguish between new and existing. This is set though the "Manage Tab" "Phases" so it is a global setting for the file. We then use colour schemes for our areas to indicate tenancy types etc.
    I was asked the other day, why a colour fill will not show over the existing element surface pattern. I though it did, but it doesn't seem to. I know there is an instance toggle in the view setting to show the fill in Foreground or background, but this doesn't seem to do anything. Its as if the existing element is overriding the colour scheme. Is this correct?
    I guess I'm a bit confused for 2 reasons:
    1) I'm sure I have had this working previously
    2) This is in out template set up, so why is this the first I am hearing of it
    Anyway, is this "normal" Revit behaviour or is this something odd?
    Andrew Harp
    BIM Manager GHD
    The same thing happens to me when the floor has a material whit a solid surface pattern
    Always
    The only thing I can think of:
    Use not solid pattern
    "-Bueno, pues ahora que los dos nos hemos visto el uno al otro -repuso el
    unicornio-si tu crees en mi, yo creeré en tí, ¿trato hecho?"
    Lewis Carroll
