General leader questions
    Hi and thanks for all the quick, accurate questions!
    1. Is there a way to have the text leaders always be from the top line or do I have to change it each time? (see image)
    2. Is there a way to change the leader style for one instance or must I create a whole new text type that uses that leader style? (see image)
    Don't know for sure (I avoid Text like the plague) but I think once it's set, beforehand, it sticks from there on.
    Yes. Arrowheads are Type based.
    Greg McDowell Jr
    about.me/GMcDowellJr
      not true, and the funny thing is, my Revit text always defaults to both arrows at the top of the text block, like the OP wants. But, I always have to change it to the two middle options as that's my standard. I think that this is a case of Revit just screwing with each users mind in it's own way.
        This should have been possible to configure in the revit.ini file. But it is not.
