Oh Rendering Teapot, where art thou?
    So, my rendering button is gone. I am in 3D View and Camera view, and I have a supported video card (nVidia Quadro). Does anybody know a fix to this? I have tried uninstalling and installing and it's still missing. Thanks in advance guys!
    JLRArch
    Sure you are not in a Sheet?
    Can you take a screenshot of the area the teapot is usually in (could give a hint)
    Alex Page
    RevitWorks Ltd
      Thanks for your quick reply, Alex. Yes, I'm sure I'm not in Sheet. I'm in 3D View 1. The teapot is usually on that lower toolbar shown in the pic below. Thanks!
        Is it also greyd out in the ribbon View Tab?
        What happens when you hit RR?
          Bjorn_K, thanks for your input. The button on the ribbon is also gone. Also, when I do the RR shortcut nothing happens. I'm not sure what's going on.
          This is a new system I built though, I wonder if there's something wrong with the video card. I might want to change it...
            Could be a corrupt Material Library installation, have you checked that the Material Library is installed?
            Windows --> Control Panel --> Programs: Look for the 4 lines shown in the attached
              Klaus, I'm missing the fourth one on that list. how do i get it?
              Thanks,
              Jose
                You might try running a repair of Revit install via Control Panel Add/Remove Programs to see if it will add the missing Material Library info.
                Cliff B. Collins
                Registered Architect
                Autodesk Expert Elite
                  So, I repaired it. I have all the libraries up and running. However, I don't see the rendering teapot still.
                    I am sure I had this issue in RAC 2011 what I did was uninstall all material libraries from Add Revove Programs, there are 4, then reinstall or repair Revit.
                    mark b
                    Mark Balsom
