create stair with seating
This topic is closed.
    Hello,
    Can anyone help me how to create this kind of staircase with different riser height and seating.
    Thanks,
    Pradnya
    I think that is going to be 3 different stairs.
      Like that:
        its very easy
        use the stair by sketch option
        Dhilip Seshan
        +91 8124181665
        www.dhilipseshan.n.nu
          Thanks Robin.
          But can you please tell me how can we change in riser height(High riser)?
          For the second picture which command did you use.
          Originally posted by Robin Deurloo View Post
          Like that:
            its the sample image. its the type you required duplicate the stair
            change the value in desired stair.
            Dhilip Seshan
            +91 8124181665
              yep create 2 stair types and give one a thread height that is twice as high as the othewr and you might need to set the maximum thread height in the family parameters for the seating.
                I'm late to this party, but I honestly don't think I would use a staircase at all for that stuff.
                I'd probably either use Structural Framing or generic models, or casework. Its a staircase, but what I would call a conventional one.
                Aaron Maller
                Director
                Parallax Team, Inc.
                  Be sure you are watching your riser heights. The original picture shows 3 risers for each large step. Build your actual stair first, then the large ones.
                  Personally I would create as an in place component since it can be assigned to the stairs category.
                    Thanks Dhilip i will try to do it.its the sample image. its the type you required duplicate the stair
                    change the value in desired stair.[/QUOTE]
