Hello,
I am confused with the Coordination System in Revit...
I have created a Template in which I have the Project Base Point in (0,0,455) and the Survey Point in (0,0,0)... because usually in my projects I have the Floor plan near to the elevation 455 (not always) so I prefer in our template, when we go in the Elevations, the levels to display like 455, 480 etc..
Now I want to import an existing project in my Template. So I start a new project using my Template...I am trying to save time, so I don't want to start the existing building from scratch in the new project from my Template so I go in the 3D view...copy in clipboard and after I paste it from clipboard in the new project.
The existing Building has the Project Base Point in (0,0,449) and the Survey Point in (0,0,0)...
When I copy it, the Project Base Point is different so I change it again in the coordination (0,0,449). My problem is that when I go to change the levels in the elevation in order to have the same levels as I had in the existing building I have this error ' Can't keep elements joined. ' because its element in the existing project has linked with the levels that I had in the template. So for example the floor plan in the existing building doesn't have the same elevation with the floor plan in the new project.
I don't know how to explain the above better...
My questions are:
1. Is it correct to copy from clipboard an existing project and past it in a new one? There is another most appropriate way to do this?
2. How I can change in my template the Coordination Systems in order to correspond in the Existing building?
Any suggestion will be useful...
Thank you in advance!
My questions are:
