Wall End Reveal
    Wall End Reveal
    Using Revit LT.
    Is it possible to do a reveal at a wall end? I've tried numerous family types and cut with other walls-they seem to need to be parallel.
    Thank you,
    Trevor Pan
    http://www.trevorpan.com
    Place it on the face of the wall and use Offset From Wall parameter to slide it on the right spot or use void in place to cut the wall at the end.
      Thank you very much. I was missing the vertical tool option (blind). Got it to work. So awesome..
      Trevor Pan
