Cutting Geometry with Toposurfaces
    Greetings
    I need to create a tholus like the Patheon in Rome. Half of it will be underground and half of it will be visible above ground level, with an opening (oculus) on top. I ve watched dozens of videos about cutting geometry with toposurfaces but the Revit system will just not allow it. Is there a way to intersect and cut a toposurface without having to create building pads etc.
    Many Thanks
    Jim
