Schedule Woes
    Schedule Woes
    I am trying to create a parking schedule that looks the one I have attached. I have tried adding parameters to my parking space family to make this achievable however I am still running into issues. Is this schedule beyond Revit’s capabilities?
    Possible......Yes
    Easy...........Not too much
    I would assign a interger parameter (Let's call him x)to each element
    Van Ada .....1
    Ada .............2
    9'x18'...........3
    On the schedule i would use a formula for each column in this way:
    If(x=1,1,0)
    If(x=2,1,0)
    If(x=3,1,0)
    and i would use "Count" for TOTAL
    Maybe there is an easier way
    I hope you can understand my "googlish"
    "-Bueno, pues ahora que los dos nos hemos visto el uno al otro -repuso el
    unicornio-si tu crees en mi, yo creeré en tí, ¿trato hecho?"
    Lewis Carroll
      I can't test it right now, but I think if you have an integer type parameter for each of the sizing fields (basically every parking space would have it set to 1) set those fields to calculate totals, don't show all instances, and use the count parameter for the total you'd come close.
      Julie Kidder
      Architect + BIM Director
        Aha! Thank you! This worked perfectly.
        Right on! This worked. Thank you!
          I'm not exactly sure what you're going for there, but does this post give you any ideas?
          https://www.revitforum.org/tutorials...-schedule.html
          Maybe define a parameter for each Parking Type that's set equal to the Count of that Type
          Dave Plumb
          BWBR Architects; St Paul, MN
