Ceiling Stuck??
    Ceiling Stuck??
    I can't move my ceiling up without it creating a new one. I somehow moved my ceiling on the left up but i selected it while the whole thing was blue see through but i cant do it for the other ones since it only gives me a blue outline. I try to put the level up to 'upper floor' where the roof on the left is but then it creates a new ceiling and the other one is still there
    how i want it
    then it creates a new one
    when you click on "move" is the "copy" box ticked (little menu that will appear Under the ribbons once you do the "move" operation)
      Looks like your ceiling is associated with the Slab Level instead of Upper Floor Level..
        oh yes MPwuzhere is correct, I completely didnt look at that but you've got different levels applied on each different element hence the different heights.
